| Author |
Message |
Quickdtoo
Joined: 28 Mar 2006 Posts: 703 Location: Vancouver, Washington
RAV4 4WD V6
Post: #16 Posted: June 9, 2006, 3:31 pm Post subject: |
| OzRavioli wrote: | I must be missing something here, I had a look under my Aus RAV and can't see the bit you refering to here. I took some photo's of what appears to be a sheild over the whole area....
.JPG) Please click image for fullsize
Now all I have to do is work out how to put those neat links or pics in here.... |
It appears that the AU version has a shield over the entire system.
Substitute [img] [/img] for the url tags. |
| Back to top |
| R4W SPONSORS |
| Back to top |
OzRavioli
Joined: 17 May 2006 Posts: 106 Location: Adelaide, Australia
2006 RAV4 I4 CV 4WD (Sold)
Post: #17 Posted: June 9, 2006, 3:39 pm Post subject: |
Thanks
_________________ 2006 Rav4 2.4 4cyl auto 4wd in black (sold) |
| Back to top |
summerwind /M
Joined: 25 Apr 2006 Posts: 1343 Location: Seattle, Washington
2006 RAV4 Limited alumni/08 Highlander Limited 4WD/ 07 Camry XLE 3.5 V6/past owner 06 RAV4 Limited
Post: #18 Posted: June 9, 2006, 3:49 pm Post subject: |
Oh god... here we go again..
The Aussies have a shield that we can't get
Oz Ravioli...
Any chance of getting a P/N from a local dealer for this shield??
| Back to top |
OzRavioli
Post: #19 Posted: June 9, 2006, 3:53 pm Post subject: |
Stay tuned, it's a holiday weekend here.... _________________ 2006 Rav4 2.4 4cyl auto 4wd in black (sold) |
| Back to top |
DittoDude
Joined: 04 May 2006 Posts: 90 Location: Charleston, SC
RAV4 - V6 - 2WD - Sup. White
Post: #20 Posted: June 9, 2006, 5:27 pm Post subject: |
Ah yes, I see what you’re talking about. It’s right under the driver’s door and yep, it needs protecting.
I’ll fabricate a guard out of thick aluminum or stainless steel, it depends on what I can find at work (industrial maintenance). |
| Back to top |
summerwind /M
Post: #21 Posted: June 9, 2006, 7:18 pm Post subject: |
| DittoDude wrote: | Ah yes, I see what you’re talking about. It’s right under the driver’s door and yep, it needs protecting.
Or just wait for the Aussie Toyota Part number for the Toyota guard in the picture. |
| Back to top |
OzRavioli
Post: #22 Posted: June 9, 2006, 10:03 pm Post subject: |
I took the guard off and found some numbers on it, they appear to be Toyota Part Numbers....any guru's out there that know?
The sheild
What holds it on, the bolts need a 12mm socket if that helps with the size.
With the sheild removed
| Back to top |
Quickdtoo
RAV4 4WD V6
Post: #23 Posted: June 9, 2006, 10:39 pm Post subject: |
The 77641-42040 is the right format for other parts that I've ordered, it would be worth a try, I'll check tomorrow.
Thanks!!
Tim |
| Back to top |
summerwind /M
Post: #24 Posted: June 10, 2006, 4:48 am Post subject: |
| OzRavioli wrote: | | I took the guard off and found some numbers on it, |
Great job
It is interesting that the shield is referenced in the shop manual as "NO 1 FLOOR UNDER COVER" (see link) The component in discussion here is called the CANISTER FILTER.
Begs the question why is this not installed on current US RAV's? Are we missing something we should have on our RAV's?
Fuel Tank Components
Now all of us on the top half of the world need to do is figure out how to get one. With Tim on the job it shouldn't take long
Thanks for all your effort |
| Back to top |
Quickdtoo
RAV4 4WD V6
Post: #25 Posted: June 10, 2006, 8:17 am Post subject: |
No surprise here, that part number isn't good according to my Toyota parts guy here in town, I'll send and email to Jacque at Toyota of Dallas, but I doubt he'll find it too.
Maybe Canada??
Tim |
| Back to top |
summerwind /M
Post: #26 Posted: June 10, 2006, 8:54 am Post subject: |
| Quickdtoo wrote: | No surprise here, that part number isn't good according to my Toyota parts guy here in town, I'll send and email to Jacque at Toyota of Dallas, but I doubt he'll find it too.
Maybe Canada??
Tim |
Can you forward the PDF I attached to the previous post and see if they can reference off the drawings "NO 1 FLOOR UNDER COVER"? |
| Back to top |
Quickdtoo
RAV4 4WD V6
Post: #27 Posted: June 10, 2006, 9:22 am Post subject: |
I did!!  |
| Back to top |
summerwind /M
Post: #28 Posted: June 10, 2006, 11:15 am Post subject: |
| Quickdtoo wrote: | I did!!  |
and still no cigar??? Toyota publishes this part in their manual and dealer parts dept's can't match the drawing to a P/N?? |
| Back to top |
Quickdtoo
RAV4 4WD V6
Post: #29 Posted: June 10, 2006, 11:26 am Post subject: |
Nope, I described the part name, the page it was on in the svc manual and still zilch, he even did a search in his parts program for the first 5 digits of the part number and then the part name, nada! Maybe Jacque will have better luck.
FWIW, there is a metal shield over the components ahead of the fuel tank, maybe there was a design change after the svc manual was created and the changed part didn't cover the canister filter or hoses.  |
| Back to top |
summerwind /M
Post: #30 Posted: June 10, 2006, 12:40 pm Post subject: |
| Quickdtoo wrote: | FWIW, there is a metal shield over the components ahead of the fuel tank, maybe there was a design change after the svc manual was created and the changed part didn't cover the canister filter or hoses.  |
The metal shield covers the canister.
Link to discription.
Emissions Canister
The mystery continues..also the "part number" might have another couple of digits (not that it helps with your parts guy) ==> 77641-42040-28
Any Canadian RAV owners care to look under the driverside door and see if the Canister filter has a shield over it or not?? |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
| Similar Topics |
| Topic |
Author |
Forum |
Replies |
Posted |
Auto lights + fog lights on Rav4 base... |
ipokrov |
4.3 Exterior |
0 |
July 29, 2010, 1:19 pm  |
Usal Road Lost Coast Northern Ca |
docmaas |
4.3 General |
1 |
July 22, 2010, 2:04 pm  |
hye...need help.. [disc brake parts i... |
bongbong10 |
4.1 General |
18 |
July 10, 2010, 9:39 pm  |
05 Rav parts questions |
voz |
4.2 Accessories |
0 |
July 1, 2010, 10:41 am  |
RAV remote keys lost |
moabi |
4.2 General |
0 |
July 1, 2010, 8:54 am  |
Powered by phpBB
Page created in 0.845 seconds with 39 SQL queries
