| Author |
Message |
noodlerooney
Joined: 01 Jan 2005 Posts: 66 Location: Coventry, Worst Rhodes Island
Rav4L
Post: #1 Posted: January 28, 2005, 6:46 am Post subject: Cargo (Boot) Light, Quick & Easy |
All I did was drill a 1.5 " hole on the left side of the cargo area about half way up, half way back and mounted a small circular light (top half chrome, bottom half translucent white) and connected it (+ and -) to the cargo light in the ceiling (just pop the light out). I removed the left side (top, side) of the rubber rear door seal and ran the wire behind this. Used vampire taps (the little red type with the female spade connector) to tap into ceiling light, used coat hanger to fish wire to new light. Light comes on with ceiling light. Very easy mod and small light throws enough light to see fine, looks good too! Took about 30 minutes to complete. _________________ 2004 RAV4L "Ravioli" Loaded, Wife's Wheels |
| Back to top |
| R4W SPONSORS |
| Back to top |
TOY
Rav4
Post: #2 Posted: January 28, 2005, 9:50 am Post subject: |
| can we see some pictures? and where did you buy the lamp? |
| Back to top |
noodlerooney
Rav4L
Post: #3 Posted: February 1, 2005, 10:49 am Post subject: Cargo (Boot) Light, Quick & Easy |
I think I got the light at Pep boys or Autozone, it was around $2.00 USD. It is one of those lights that is used for the rear bumper (license plate) of a pickup truck. I had to solder a ground wire to the light fixture since it was designed to ground via the body of the light mounted into metal.
The rear cargo cover prevents the light in the ceiling from reaching the cargo area, it's not that the ceiling light is weak. You can see the rear cargo cover in the top of the picture, the new light is center right.
 Please click image for fullsize
Last edited by noodlerooney on February 3, 2005, 4:43 am; edited 12 times in total |
| Back to top |
CBaker
Rav4
Post: #4 Posted: February 2, 2005, 7:26 pm Post subject: |
| Is it one of those lights that is used for the rear bumper (license plate) of a pickup truck. |
| Back to top |
Mohit 27/M
Joined: 30 Dec 2004 Posts: 676 Location: Melbourne, Australia
Post: #5 Posted: February 2, 2005, 8:22 pm Post subject: |
The lighting in the 4.2 boot must be pretty weak if you have to add additional lighting. The lighting in the 4.1 boot is pretty good...but an LED bulb would make it just that bit more brighter  |
| Back to top |
nickp
XT4
Post: #6 Posted: February 3, 2005, 11:57 pm Post subject: |
| Mohit wrote: | The lighting in the 4.2 boot must be pretty weak if you have to add additional lighting.  |
Pretty bad - It's non-existent !! |
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
| Similar Topics |
| Topic |
Author |
Forum |
Replies |
Posted |
Westin Safari light bar |
joel |
4.1 Accessories |
2 |
February 5, 2010, 4:51 am  |
low beam light bulbs... optibright &a... |
NICKRAVINOS |
4.3 Exterior |
4 |
February 4, 2010, 2:39 am  |
int wiper and dome light |
Peeta01 |
4.1 Faults & Fixes |
3 |
February 1, 2010, 9:39 am  |
Flashing Air con light. |
slaine |
4.2 Faults & Fixes |
1 |
January 30, 2010, 7:48 pm  |
Light rail stimulus |
nouse4aname |
Off Topic |
12 |
January 28, 2010, 4:57 pm  |
Powered by phpBB
Page created in 0.576 seconds with 31 SQL queries
