RAV4World - Forum Index
Forum Sponsors
AMSOIL - discuss
DrinkDocker - discuss
OEM Fit GPS - discuss
PadsPlus - discuss
ScanGaugeII - discuss
Home
Album
Guidelines/FAQ
History
Links
Memberlist
Mods/Maint/TSBs
Register
Search
Sponsors
Log in to check your private messages
Log in
Metal shavings in first oil change.....normal?
Goto page 1, 2  Next
Post new topic   Reply to topic   Printer Friendly View    RAV4World - Forum Index -> 4.3 Mechanical
 View previous topic :: View next topic
Author Message
JungleJim
Post: #1   PostPosted: July 8, 2009, 5:07 pm    Post subject: Metal shavings in first oil change.....normal? Reply with quote
I just drained the oil for the first time in my wife's new RAV4.
For the heck of it, I ran my finger across the bottom of the drain pan. I noticed a few pieces of "grit". Upon closer inspection, I determined that they were probably pieces of aluminum.
Is this normal for a first oil change? I know the purpose of changing the oil for the first time with low miles is to get all of the little pieces out of the oil, but I didn't think I would actually be able to feel or see them.
I'm debating about going back up to Walmart and getting some cheap dino oil to run through it, then drain it again prior to putting in the the Mobil 1.
Is this normal?
Back to top
View user's profile Send private message Bookmark and Share
R4W SPONSORS
Forum Sponsors
AMSOIL - discuss
PadsPlus - discuss
Back to top
John E Davies
2007 V6 Ltd 4wd
Post: #2   PostPosted: July 8, 2009, 6:36 pm    Post subject: Reply with quote
No it is not normal. Modern engines don't have stuff floating around in them like in the bad old days.
Did you keep the filter element? What did it look like? Take a magnifying glass for a close look, and flush it with solvent into a clean pan or paper towel to see if anything comes out.
If it looks bad, tell your dealer and have them do the next oil change. If there is metal next time, you have a problem. Well - they have a problem, you most likely get a new engine.....
_________________
John E Davies
Spokane WA USA
Back to top
View user's profile Send private message Visit poster's website Bookmark and Share
BigSwede   /M
2008 Silver Base V6 AWD
Post: #3   PostPosted: July 9, 2009, 5:21 am    Post subject: Reply with quote
IMO it is normal for the first change...shouldn't be any for the 2nd change though.
_________________
~Steve in Minnesota
Back to top
Zeoth   /M
2008 Pearl White Limited V6/4WD 3rd Row
Post: #4   PostPosted: July 9, 2009, 8:09 am    Post subject: Reply with quote
I agree it's somewhat "normal" but it all depends on how much came out. A little not a big deal. This is why I always overchange my oil on new cars. I usually change at 500, 1000, 2000 3500, 5000 and after that I go every 8,000-10,000 miles on full synthetic.
_________________
Cars, snowboarding, house modding.
Back to top
Zeoth's gallery View user's profile Send private message Bookmark and Share
Colonel
1991 Toyota MR2
Post: #5   PostPosted: July 9, 2009, 9:49 am    Post subject: Reply with quote
Where is flyingn when you need him? Laughing I to subscribe to the "overchange" cycle at the beginning.
_________________
2007 Rav 4 2AZ-FE (Auto Sad )
1991 MR2 3S-GTE (Gen III, 5 Spd)
2001 Maxima SE VQ30DE-K (5 Spd)
Back to top
Colonel's gallery View user's profile Send private message Bookmark and Share
mensajero
5+ Year Member
1997 White/RAV4/2WD
Post: #6   PostPosted: July 9, 2009, 9:53 am    Post subject: Reply with quote
If you ask me, No, it isn't normal in any engine, new or old. Once it's running in the system sooner or later something will expire. Be it bearings, cylinder walls, etc. Check the particles that you have and try to see what kind of metal it is. If you can post a picture of them maybe someone in the forum might be able to ID the metal. Maybe even be able to tell you where is comes from. If you are doing the cheap dino oil, use some engine flush also. Try to see if their is more particles. If so, you got a problem, better yet, your local Toyota dealer has a problem.
_________________
http://www.cardomain.com/ride/400637
Back to top
mensajero's gallery View user's profile Send private message Visit poster's website Bookmark and Share
BigSwede   /M
Post: #7   PostPosted: July 9, 2009, 10:15 am    Post subject: Reply with quote
Every new engine I have changed oil on has some metal particles in the pan, on the filter, and on the magnetic oil plug the first time, including my RAV4. This is a normal product of manufacturing process. And I have never had an engine that blew up or even burned oil in lengthy service.
_________________
~Steve in Minnesota
Back to top
Esc
2009 Magnetic Gray Metallic V6/Sport/2WD
Post: #8   PostPosted: July 9, 2009, 10:32 am    Post subject: Reply with quote
It is normal. What you are seeing is the break in of the pistons. As they move they create their own custom seats withing the cylinder. The metal you are seeing is what is discarded during the seating process. This is what the "break-in" period is all about.
Back to top
RTexasF   61/M
2008 Savannah Metallic/Base V6/ 2WD & 2008 Blizzard Pearl V6 Limited 2WD
Post: #9   PostPosted: July 9, 2009, 4:47 pm    Post subject: Reply with quote
My question is how clean was the pan that the oil was drained into? Was it totally spotless? No chance whatsoever of crud on the bottom of the pan? I think this could be much ado about nothing. Drive the car and enjoy it. Don't look for problems where none exist.
It would certainly be worth checking the filter and the (clean) pan on the next oil change I would think.
_________________
Old Bird......sometimes wise
Back to top
flyingn
2006 Rav4 Limited/I4/4wd
Post: #10   PostPosted: July 10, 2009, 9:38 am    Post subject: Reply with quote
here I be. Yes there is a very good chance of metal shavings in a new engine. I have some sorts of maching leftovers in every new cars that I have changed oil in the last 25 years. For the cost of an oil change its surely not worth it not to change the first oil at 500 miles or so.
_________________
Defender of the 4 banger!!!!
http://tinyurl.com/7zoma <= website!
Back to top
flyingn's gallery View user's profile Send private message Visit poster's website Bookmark and Share
friendly_jacek
2006 RAV4 V6/base/3rd row/4WD
Post: #11   PostPosted: July 10, 2009, 9:00 pm    Post subject: Re: Metal shavings in first oil change.....normal? Reply with quote
Is this normal?
Is yours V6? I saw that in mine at 23000 and 28000 miles oil changes. Very small and only visible in direct sunlight (glitters). Elongated but very thin. Nonmagnetic=aluminium. Bothers me some. I did oil analysis once and came back fine. The only reassuring thing is, most people don't look at used oil sediment under bright light, so it may be common but underappreciated.
Back to top
friendly_jacek's gallery View user's profile Send private message Bookmark and Share
friendly_jacek
Post: #12   PostPosted: July 10, 2009, 9:05 pm    Post subject: Reply with quote
You are hurting the engine by doing that. It has been proven that new oil produces more friction and wear. I posted about it on BITOG:
Link
Back to top
SteVTEC   32/M
2007 Barcelona Red Sport V6 4WD
Post: #13   PostPosted: July 12, 2009, 9:19 pm    Post subject: Reply with quote
Link
Yup. And I see you have that backed up with some actual SAE white papers. Very nice. Thumbs Up As proven by my own oil analysis on my RAV4 at 5000 miles, the factory fill oil is A-OK to go the full 5000 miles. Absolutely no need to change early.
_________________
Steve
07 RAV4 Sport V6 4WD, driven like my Maxima
02 Highlander Ltd V6 AWD (wife's)
99 Nissan Maxima SE 5spd (Sold)
01 Honda Accord EX V6 (rip)
If you have a "whining" 4.3 in the DC area, PM me for a meetup to compare.
Back to top
SteVTEC's gallery View user's profile Send private message Bookmark and Share
georose
07 Rav4 Sport V6 4WD
Post: #14   PostPosted: July 13, 2009, 12:51 am    Post subject: Reply with quote
Yes, I think it is most important not to change the oil prematurely during break in.
Back to top
Zeoth   /M
Post: #15   PostPosted: July 13, 2009, 8:13 am    Post subject: Reply with quote
Link
Good find but at the beginning I'm more willing to over change the oil to protect my engine from shavings and to flush more often. Once I steady out, it's pure synth at 8k-10k miles.
_________________
Back to top
Display posts from previous:
Post new topic   Reply to topic    RAV4World - Forum Index -> 4.3 Mechanical All times are GMT - 8 Hours
Goto page 1, 2  Next
Page 1 of 2
Jump to:
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot vote in polls in this forum
Similar Topics
Topic Author Forum Replies Posted
No new posts Hit a Pothole.. Ran Over a Metal Pipe... NYPD 4.3 Mechanical 15 July 27, 2010, 7:29 pm View latest post
No new posts Initial Oil Change mostlypeaceful 4.3 General 8 July 26, 2010, 1:01 pm View latest post
No new posts transmission oil change & spark plug earthrealm 4.2 Faults & Fixes 1 July 23, 2010, 7:37 am View latest post
No new posts metal rattling sound front end when d... Andy F 4.3 Mechanical 1 July 19, 2010, 3:16 pm View latest post
No new posts spark plug change MotoMike 4.3 Mechanical 5 July 18, 2010, 6:00 am View latest post
Back to top / RAV4World - Forum Index
Powered by phpBB
Page created in 0.688 seconds with 37 SQL queries
This site is not authorized by or affiliated with TOYOTA or its subsidiaries.
RAV4World, All Rights Reserved [Disclaimer/Privacy]
