| Author |
Message |
colchiro
2005 Drunken Rav: 2.4L AWD Limited
Post: #1 Posted: April 17, 2008, 7:00 pm Post subject: Sensor documentation. |
I found a nice collection of documentation on Toyota sensors, their location and troubleshooting and theory. I thought I'd share. http://www.autoshop101.com/autoshop15.html _________________ Rick |
| Back to top |
| R4W SPONSORS |
| Back to top |
colchiro
| Back to top |
colchiro
| Back to top |
colchiro
Post: #4 Posted: July 2, 2008, 3:06 pm Post subject: |
Here's a way to lean out your air-fuel mix by tweaking the MAF sensor:
See the upper left portion of this image. (The right side is plans for dual controls, like city, highway.)
Parts needed, small project box, 50k linear 1W potentiometer, 33k 1/4 resistor, small knob, SPDT switch and wire. Parts should be available at your friendly neighborhood Radio Shack store.
Cut your MAF sensor wire (by the sensor under the hood, or by the ECU in your vehicle). Usually this sensor is between the air cleaner and the engine.
Take a 50k pot and connect one end of the pot to the output of your MAF sensor (green wire in diagram), center terminal of the switch goes to the ECU side of that cut wire (black wire in diagram) and the other end of the pot to ground via a 33k. _________________ Rick |
| Back to top |
colchiro
| Back to top |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
| Similar Topics |
| Topic |
Author |
Forum |
Replies |
Posted |
Replacing rear O2 sensor and rusty pi... |
lvolleyer |
4.1 Faults & Fixes |
0 |
July 28, 2010, 4:02 am  |
02 sensor heat shield needed? |
haveyourcake101 |
4.1 General |
5 |
July 14, 2010, 4:44 pm  |
Noobie help please! [Lambda sensor?] |
Cirrus RAV |
4.2 Faults & Fixes |
2 |
June 26, 2010, 2:42 am  |
MAF Sensor? |
nwoverlander |
4.1 D.I.Y. and Modifications |
14 |
June 23, 2010, 5:47 pm  |
Need Help with O2 Sensor |
johnyd |
4.3 Mechanical |
8 |
June 16, 2010, 9:21 am  |
Powered by phpBB
Page created in 0.335 seconds with 27 SQL queries
